Hi.
I have the folowing issue with my iPad and I want to know if there's anything I can do to fix it.
Every time I'm in a bad recepction spot my iPad stops working on 3G. It shows the 3G and provider name but I cannot navigate or get email. I try turning Airplane mode for a couple of minutes and then back of to reset the connections but still nothing.
The only way to get connection is to turn off and then on the iPad and it gets service again.
There is any way to avoid this procedure?
Thank you.
Thank you.
