Audio Issues
enron29
Hey there, need some help. Recently, I have been using DVDFab to rip my DVD's that I own to .m4v files so I can put them on my iPad. Everything got converted fine and put on my iTunes, and transferred to my iPad. However, the audio is not playing. The video plays just fine, but the audio is not coming through. If I scrub forward, I get some audio, but it keeps repeating like a broken record. Any ideas? I was really bummed when it didn't play correctly.
OK - this probably won't help, but it's easy so not much lost if it doesn't...
Have you tried completely powering the iPad down rather than simply putting it to sleep? Press and hold the Power button until the slider control appears?
Even Apple recommend this procedure every so often and it seems to fix a whole range of 'unexplained' issues.
