Kevin43 iPF Novice Sep 18, 2013 #1 Hi Does anyone know if it's the same in iOS 7 when you battery is fully charged you will see a plug in the battery? Thank you
J Jack_Sparrow iPF Noob Sep 19, 2013 #2 Kevin43 said: Hi Does anyone know if it's the same in iOS 7 when you battery is fully charged you will see a plug in the battery? Thank you Click to expand... No it shows the percent of battery you have,and the battery turns greeen,With a scar on right side of it
