Hi there,
I am at my wits end so I hope somebody in this forum can offer me some help. My Ipad is on iOS 4.2.1. For some bizzare reason, the Ipad would AUTOMATICALLY connect to the wifi by itself and launches the youtube application in sleep mode.
This is what I normally do after toying around with the ipad.
1.) Close all applications
2.) Turn off wifi
3.) Put the ipad to sleep
After about 6 - 7 hours when I turn on the Ipad again (after "Slide to Unlock"), the youtube applications will be open in the background. Double tapping the home button will reveal the Settings and Youtube application to be running. Wifi will be turned on inexplicably as well. Battery life would deplete by 10% within the 6 - 7 hours. Volume would set itself to 0. What is going on?!!
I have disabled all notifications. Disabled Ping. Disabled Push. All to no avail.
I am going crazy trying to figure out what the problem is. I thought it was my router that is causing the problem so I borrowed a different router from a friend but I am still experience the same problems. I don't mind that it auto connects to youtube and turning on wifi, but the battery drain is too much. I seriously doubt that there is a hardware malfunction because this is the 2nd ipad that is experiencing the same symptoms. My first ipad have experience the same bizzare symptoms and I sold it at a very low price because I thought it was faulty. After getting the 2nd ipad the same problem persists.
Any help would be much much appreciated! I am seriously considering ditching Apple and jumping on the android bandwagon!
2.) Turn off wifi
