WaterMark
I want to add parental control on my boy's ipad, is there a software (something is more like a porn filter,however this one is only uesed for PC) to block website? Any ideas will be appreciated.
Check out the iPhone configuration utility. There are some limited parental controls which can be set on the device, using the tool, such as "block explicit content"...not sure if that is granular as you want. You can set the profile so he can't remove it without erasing the device. Also not sure if it applies only to iTunes purchases or not....one way or the other it's an interesting tool to experiment with.
There are so many softwares available, as told by members above but I think ipad itself provides prevention. Just go to ipad explorer > Options and you will see parental control options to restrict explicit content.
