Hi, thanks for the prompt reply. Unfortunately there is no update and shutting off and re starting didn't work.K1W1 said:First of all turn your iPad off completely and then restart it. If that doesn't work check the app store for an upgrade to the app you are using.
I emailed the developer and got a prompt reply beck saying that the update is in the App Store for approval. I hope it doesn't take too long since I am using it on a daily basis for my trip.charlyee said:Hi, thanks for the prompt reply. Unfortunately there is no update and shutting off and re starting didn't work.
Hello all, after updating my BlogPress app does not open. I am in the middle of my travel blog.
Please help !
I un installed and re installed and it was working fine until yesterday. I had same problem as you and un installed and re installed it many times. I finally decided that I would just post to the web however much I had instead of saving as draft and that seems to be holding up, maybe you can try that?Did you ever get it to work? I just updated to IO5, wrote a blog post, and as soon as I saved a draft, it started crashing and I cants get in. I emailed developed but no reply yet
charlyee said:I un installed and re installed and it was working fine until yesterday. I had same problem as you and un installed and re installed it many times. I finally decided that I would just post to the web however much I had instead of saving as draft and that seems to be holding up, maybe you can try that?
Please post what the developer said, this app is not playing nice with iOS 5.
Well it crashed again, fortunately I had only made two changes and tried to save it. I see everyone complaining about it in the App Store, and are waiting for an update that is awaiting approval.Wislanscraft said:Thanks! I uninstalled and reinstalled and was able to update my blog, although I had to start from scratch on the post I had almost finished. For safety's sake, I published and *then* proofread it. I'll let you know what developer says as soon as he/she responds...
