Is it me or does the iPad take a long time to fully charge. I plugged mine up hours ago and so far it's at 70% charged. When I started the charge it was at 19%.
Was the iPad turned on or off? Obviously, if the iPad is switched on the machine itself is drawing current to operated, leaving considerably less available to charge the battery.
I guess you're using the 'proper' iPad charger and not either an iPod or USB-PC style charger, which will certainly take a very long time.
If you are using the USB and charging via computer it will take a lot longer than using the AC adapter.
Actually not using the computer but I was using my iPhone charger so that may be the issue. Thx
