Couple Of Small Problems
Querty
Hi guys new here hope this is the correct section,these are small issues but they are niggling me,the IPad is a 6 generation and has copied my data from my old IPad 2 including the apps it had on,my National Lottery app icon now doesn’t have the logo but a circle with lines through it a bit like a rifle sight,I tried deleting the app from Cloud but it never seems to go and when I go to App Store it is there with the little cloud symbol,it always comes back without the logo. Can I delete it completely and reinstall ? Also on Safari should the section that pops out when you press favourites be shaded blue at the top and a pinkish colour at the bottom ? It looks a little odd to me. Many thanks for looking this IPad is so good compared to my old one.
Welcome to iPad Forums, Querty!
If the app is still in the app store you can delete it from your iPad and then go to the App Store and download it. If the app is a paid app you will not have to pay again to redownload it.
Thanks for the welcome and the reply,yes went to the App Store after deleting from iPad but it has the cloud symbol I think saying it’s stored in the cloud as a back up,I wanted to delete it completely and install it fresh.
It is deleted completely from your iPad. That cloud symbol doesn't mean it's stored in the cloud anywhere, it just means that it is a previously downloaded app that is not currently on your iPad. Clicking on the cloud symbol will download the app to your iPad just like the first time you ever installed it.
Ahhh that explains a lot thank you,wonder why the lotto icon is missing ? I know it’s only a small thing I just wanted this new iPad perfect,still getting used to it the operating system is light years from the old one,thanks again for the help scifan 57.
here’s a screenshot of the icon it’s bottom left,excellent camera on this pad.
What happens if you reboot the iPad? Press and hole both the power and home buttons until the Apple logo appears, then release both buttons and wait for the iPad to restart. BTW, is the app working normally even with the blank icon?
