ActualBrago
I have Downloaded a tweak called date slider from cydia and now i cant unlock my ipad it just shows the date with no slider and when i slide my finger across nothing happens.
I had the same problem.
I have an apple smart cover. You can find it on the apple website.
After opening the cover, the iPad bypassed the "slide to unlock" screen so I could enter my password. I then uninstalled the date slider in cydia and now everything went back to normal.
If you do not have a smart cover, you could try activating the iPad by tapping a magnet around the edges.
