graywolf
Do you think it matters if I run the battery to 1% instead of running it until it completely dies?
Just for the monthly battery calibration.
Mountainbikermark said:2% is a safety factor. Though the battery isn't dead dead it shuts off at around that point. Your battery calibration could be off by the 1% difference.
Support Our Troops!
This post was Tapatalk approved
SweetPoison said:My iPad only goes to 2% then kicks off ~
Oh! I thought you were answering the OP but you ARE the OP! I am trying to do 500 things at the same time! Grayson ~ does your iPad make it to 1%?
SweetPoison said:Didn't I say 2% and then kicks off? Did you ever go to your room?
sjleworthy said:I've run mine down to zero a couple if times.
Battery calibration? What's that? I really don't think running your battery down/to zero makes a hill of beans difference. But once a month? What a faff. Just use it as you go![]()
