Heating Problem !
baykolesterol
My iPad 2 have heating problem about over a week. Not too much but it feels. why did it start to heating or is it normal ?
Where you from bro? Is it not winter time where you are and you only notice the heat now since it is colder outside?
i live in Istanbul / Turkey and here is 37 C degree. Here is hot enough and getting hotter :s
Hehe.
Heating problem is normal when you are playing games or browsing the web. Its not any problem but if it is over heating then you need to be worried.
thanks
Heating is only a problem if you iPad shuts down with an on screen indication that the thermal cutout has tripped. You cannot miss this warning and the iPad has to get exteremely hot before this happens! Anything else is just normal heat from internals being disspated by the case and should not be a cause for concern.
