Twowit2woo
Hi there,
Never jailbroken an iPad before so decided to give it a go. All went absolutely fine, the evasion app said "done" then the ipad rebooted - and now that's where it's stuck. It just keeps on rebooting perpetually, won't break out of it.
I tried:
a) holding the power button to switch it off, waited a bit then powered on again
b) holding both buttons (hard reset?)
c) hard reset followed by holding the volume up button.
Nothing will break it out of this loop.
Is there anything else I can do?
Many thanks in advance.
I tried:
