Help having problems update Jailbroken Ipad 1G
Lxx
Hi All
I am looking for help
I have a Jailbroken IPad 1G running 4.4.2, my itunes is the current version 10.3.1. (Running Win XP PC with security essentials)
I am having trouble updating my Ipad to the latest firmware 4.4.3
The update 4.4.3 downloads,extract then.
It stops after trying to verify the 4.4.3 with itunes & give me an error code (3194) in itunes.
Has anyone had this problem & fixed it?
I though about doing a restore but i an worried it may fail in the same way,
Hi All
Have a look here
http://www.ipadforums.net/jailbreak...-how-resolve-itunes-unknown-error-3194-a.html
And btw - latest firmware is 4.3.3....
OUTL4W
Thanks for your help
It worked, updated to 4.3.3,
Tried to then latest Jailbreak via safari.
It didn't work for me Cydia Icon appeared started downloading as soon as it started to install, the Cydai Icon just disappear.
I think I might have to try to Factory Restore to 4.3.3 rather than update.
And try the Jailbreak again.
Once again thanks for you help.
