HELP.. ipad apps not working ( not opening ) after jailbreak? what to do??
kiro28
HI.. need help... i have an ipad.. my friend already have installed games on it,like temple run .. but i jailbreak my ipad.. after i finish jailbreak.. i cant open my apps.. what should i do.. plz help.... tnx...
Please don't keep posting the same message all over the forums. Ask once, and please have patience until somebody answers you. I shall delete your other posts. Thanks for your understanding.
Jailbreaking should not prevent you from opening your apps, however you can sometimes run into problems with permissions.
1) fully reboot the iPad (power off, then back on again).
2) if Temple Run will still not open, remove the app from the device (hold the icon, then press the cross that appears).
3) Reinstall the app from the iTunes store. It should now run as normal.
my apologies.. i'm so sorry.. and thank you..ahmm.. but all of my apps (games) install on my ipad is not working...? do i need to re-install all my games?? but thanks.. i will try to re-install the app..
thanks again...
and sorry...
Hi and welcome to the Forum!
Hope you get those apps sorted.
iPad 2 3G 64gb
hi i also have a problem with my Ipad, i recently jailbreak it. when i try to add new games from itunes, it does not sync. this is the second time i tried syncing new games from itunes to my ipad, the first one went well. but this times its not working.
i am thinking to remove the jailbreak but wanted to consult you guys first, maybe you have a remedy to it. thanks in advance....
