Help iTunes on iPad won't work
Sab1989
Uk
Hi for some reason my iTunes is not working properly on my ipad yesterday it worked fine but today it won't load up the
Pages properly it loads genius and purchased page ok but not films, music ect I have tried resetting but still won't work?
Try the time-tested and best solution to any iOS issues... Power off your iPad and then turn it back on.
Note: To power off, just press and hold the power button for about 5-10 seconds. You will then see the option Power Off. If you just press the power button, the iPad will turn off immediately and go into standby mode.
