Purplehaste
when i connect my ipad to my computer via USP it said not charging how do i fix this??
KevinJS said:You need USB 3.0 to charge the iPad from a laptop.
KevinJS said:You would need to look in the Windows System to find out, or whatever the equivalent is on a Mac.
Unless your computer is quite new you are unlikely to have it, although its possible to buy a card with up to 4 USB3.0 ports on it. They are very easy to install on a desktop.
Purplehaste said:when i connect my ipad to my computer via USP it said not charging how do i fix this??
