Are you using DropDAV so that you can copy directly to and from DropBox?
If not go to dropdav.com and get an account that is associated with your DropBox account. Once you do that you can download and upload files directly from Numbers using the WebDAV option.
From the list of documents in Numbers you use the arrow coming out of the box to upload/export spreadsheets, and the arrow going into the tray/box to download/import spreadsheets.
There are other ways, but this is the most efficient way to get files to and from DropBox from the iWorks apps.
Note: While it is possible to use GoodReader to OpenIn Numbers, there is no option to OpenIn from the iWorks apps.
