Help with Pages required please!
Becs
Cambridgeshire
I've just bought "pages" with a view to using it for a few specific purposes. One of them is my need to create an "ingredients" card which I was doing in publisher on my notebook. Now I can create something perfectly ok in Pages however they are all A4 and I really need something that I can print onto 10 x 15 cm photo paper. I can't seem to find a template or any way of changing it to this size when I print. Can anyone help with whether this is possible or what app I could use instead?
Here are some blanks and templates I created in in the OS X version of Pages; along with other random documents I've share here at one time or another. You can import them into the iOS version of Pages and use them. Remember to work with duplicates so that you don't mess up the original.
I just added a 10x15 cm template. It's in equivalent inches, because Pages would not let me change the units.
Forum Stuff - Folder Shared from Box
Thanks ever so much. That's really helpful. Is this a stupid question but can it be rotated to be portrait?
I can make you one that is. Hang on and I'll add it to the folder.
Update: Ok, it's online, same place.
P.S. Not a stupid question. One of the reasons I made this bunch of templates is because you can't rotate the built in page sizes.
