How to increase sound volume?
Otto...Also have a low volume problem on this bran new IPAD-2. Pressed the home button twice but no multi-tasking came up.
Same "game" I had on the IPAD-1 with plenty of volume but nothing on this one and it's not on mute. There "is" volume but not on this app?? Thanks! Ken
Then 1. Make sure you have IOS 4.2 or higher.
2. You can go to settings-general-sounds an there you can find a volume switch.
3. You can always go to your local apple store or best buy and other electronics stores.
4. I hope this helped you ;)
iPad 2 wifi only 32GB
Volume control
SHAZAAM! Hitting the home button twice revealed a previously unknown-to-me
volume control device. Many thanks for the help.
