justlearning
- Joined
- Mar 16, 2013
- Messages
- 11
- Reaction score
- 0
I have an ipod 2 that wont power up, from the research I have done I have found it recommended to power it down pressing home and power button and then repowering it on. if that fails then try to plug in for 30 mins to the wall and try again.
if that doesn't work then it is most likely a hardware failure.
I have tried charging it and it is not working- when charging it I see the battery come on the screen but it doesn't gain any charge, I also tried to plug it into my computer to connect it to itunes and it shows that it is receiving a charge from the computer on the pad but isn't recognized in itunes. if it is a hardware failure what normally goes out that would cause this? also I am wondering could it be that battery is shot... I am just wondering what I can do for trouble shooting find a the cause.
thanks
thanks
