Initial battery Charge?
I would charge at least 24 hours !!!!
Before you turn it on !!
Late April Fools joke.
If you could do that you are much stronger than I could be.
I actually have no idea what would be best.
Steve said in the keynote that it has a month of standby time. If they gave it a decent charge before packaging it, it should still have plenty of power for us to play with when it arrives. We will find out for sure very soon ;).
Reality is the first thing you'll do is sync it to iTunes so while it's plugged into your pc it's charging. So you can play and charge at the same time. I'll probably have it plugged on charging the whole first day I get it while I set it up, explore features, and of course buy a bunch of new app's. Ok, back to obsessing over "Late April".
Here is the question. Let the unit drain completely and then charge it up to 100% or charge it right away?
There are many theories with batteries and memory (as in, the battery remembering the paramaters of full charge vs full drain).
That's the great thing about lithium ion, they have no memory so you can charge them at any point in cycle and no degradation.
iPad Charging time
Johnny, with almost 23 years experience in electronic field, i can agree with you about the theories .... but in fact if you know well how the battery is made and the charging/decharging system include PCM management ... you will know at the first time you have to totally discharge your device by playing with :) after the best is let it in charge for almost 4 hours (based on the 10 amp Apple charger, after you do what you want and charge it when you want ... the battery come with little energy for the testing in the assembling line ...
one day i will publish pictures about the factory making the battery for iPad & iPhone (he his one of our supplier)
