Ipad 2 Bluetooth Headphone Problems
The Spackman
Glasgow
Hi there,
I have a pair of Sennheiser MM400 Bluetooth headphones. They work with my iPhone 4 a treat over Bluetooth but when I use them with my iPad 2 the sound cuts out every few minutes. I simply have to press the main action button on the side of the headphones and the sound comes on again but it's a touch irritating.
This sound cutting out is not consistent either. So far I have observed the following.
On iPod - if screen off, cuts out every few mins as described. If on is OK.
On some games (plants vs zombie's for example) - cuts out even if screen on.
On BBC iplayer the program will sometimes randomly stop. Pressing action button on phones starts it again.
It seems like a software problem of some sort so I am hoping it is fixed in an update sometime. Is there a known issue with ipad2 and Bluetooth headphones?
Overall my iPad 2 rocks apart from this niggling issue.
Thanks in advance for any help you can offer.
OK - before we get down to more complex solutions, let's try the simple ones first...
If these don't help - get back to us and we'll move on to some other possibilities...
Hi Tim - gave both your suggestions a try then tested extensively yesterday. While I'd say the problem has lessened it's not eliminated. It was not cutting out nearly as often but appeared more random with sound sometimes flowing uninterrupted for 20 minutes then other times cutting out a few times a song.
I'll keep playing around and see if I can identify any more patterns that help identify the cause.
Cheers.
Let us know how you get on and, if the problem persists, we'll see if we can come up with some further suggestions.
I can't recall - have you tried unpairing the headphones and then pairing them again?
Yeah - tried unpairing but no difference.
Still beffuzled tbh. Got almost an hr with no pauses yesterday afternoon and no rhyme nor reason for it?
I'll be in touch :)
Mine does this as well...different headphones though
I have the same cutting out sound on my Nokia BH-905 bluetooth headphones.
Never had this happen on the original ipad. I hope this gets fixed soon.
Sorry to hear you have the same prob mtltdi but glad I have someone to share in the sorrow :)
Since re-pairing and rebooting it's been noticeably better and much more bearable so I suggest doing that till a fix is found. Just a bug I am guessing?
Having the same issue myself with Motorola S9 Bluetooth headphones - audio playback skips intermittently using the IPod app on IPad 2 - definitely annoying. Using standard headphone results in no audio skipping. Reboot / Re-Pair to no avail.
Have you fixed the issue, if yes add me as a friend so i can fix my nokia headphone, same problem. :confused:
Just a data point, I'm using the Motorola S305 BT headset with my iPad 2 and it works flawlessly (in terms of keeping a solid, continuous connection). They're not loud enough, and there's a little more hiss than I'd like, but the signal is solid.
So it's not a universal problem.
I wonder if 4.3.3 fixed it, I only use them when on the plane...will check in later.
Just a bump that this is still a problem. iPhone is flawless with my Bluetooth headphones and given up on using with iPad for the moment if I can avoid it.
I just wanted to post to say that I've been having the same problems with the iPad 2 ever since I got it. My bluetooth headphones are Sennheiser MM450 and they work fine with my Sony Ericson phone.
When listening to a podcast, the file will stop playing every now and then and I have to press play on the side of the headphones to start it going again. Very strange.
Oh great! I've been using Motorola S305's on my iPad 2 without any problems. Because I liked the whole bluetooth headphone idea so much I decided to invest in a really good pair of BH-905i's ... Received them today, and yeah guess how I found this thread :(
Hello Community:
I have been having problems with my iPad2 Bluetooth. I am currently using the JayBird Freedoms Bluetooth headset (see attachment) and the iPad2 hasn't been able to even 'discover' them. I use these everyday with my iPhone 4 (even with the new FW 4.3.4 on both devices).
Is anybody having the same problems?
