Xclusive
Hello everybody,
I recently bought an iPad 4 Wifi 32GB (black version).
I have used it for like a month and a half now and I experienced some issues with my iPad.
In short, I have two problems:
Problem 1
I recently downloaded the app called "iDJ2GO".
It's a dj app where you can mix music.
This app also contains an equalizer with three options: bass - mid - treble.
When I was playing music (electro house) I turned down the mid button.
Besides the song it was playing, I also heard a crackling sound. (it's difficult to describe).
Then I turned the mid button up again and the crackling sound was gone.
I don't think the speaker is blown up because the volume was only as high as 50%.
The sound wasn't very loud.
When I play music from the music library I hear a cracking sound.
This is especially noticable when the music part contains high frequencies.
I just think the sound of the speaker isn't as good as it used to be.
Normally an Ipad would sound clearly when it plays high frequencies.
Problem 2
My iPad speaker makes static noise when pause the music. (it disappears after about 10 seconds)
It isn't loud and you can only hear it when you put your ear in front of the speaker.
The static noise als appears when I play music and turn the volume down to 0.
Maybe me speaker must be replaced.
And I already did the 10 seconds reset with the home button and sleep button.
My questions are:
1) Do you think it's normal? (I don't think it's normal).
2) Have you experienced the same problems with your iPad?
3) Do these problems fall under warranty?
I hope to hear from you because I don't really know what to do.
Jorn.
Problem 1
Problem 2
My questions are:
Jorn.
