Ipad -Important note deleted accidentally.. need urgent help to recover
imrock
UAE
Hi, i created an important note on my new ipad.. i accidentally selected all data on that note and hit the "8" key.. all the data was replaced by "8".. as i didnt know how to undo, i opened a new note and the old note vanished..PLEASE.. advise on how i can recover that note!! many Thanks in advance!!!
To chime in with the others, yes, UNDO was your only option.
For the future: To undo, press the .?123 key on the left side of the keyboard. An undo button will show about in the same place. Pressing that will undo any actions. Do note that it will undo all the way back, in steps. So, if you delete something in one step, it'll undelete it. Then, if you press undo, the step you did before the delete will be undone.
For example, I typed "test test test." Then, I highlighted the last two "tests" and hit the delete key. Then, I pressed the undo key and the two words came back. Then, I pressed undo again and all the words disappeared (which was the last action I performed before the delete...typing the three words).
Hope that made sense. Oh, and do remember, there is no REdo key. It's undo or nothing. And, if you leave the note before applying the undo, it won't work.
Sorry this is too late for your situation - but maybe this info will help in the future.
Hi - first of all, since all things are possible to those that believe, IF your note was ever saved to the ipad (meaning you didn't lose the note before it was ever titled & saved by the notes app) you could potentially have a data recovery specialist locate & recover the data. Depends on how much you value that content...
Secondly, perhaps it was not possible in older versions of iOS, but in the version i'm running—iOS 5.1.1, non-jailbroken—you can undo an action as described above, but you can also redo. Simply press the .?123 key, then the #+= key and, voila!, undo has turned to redo which can also be applied in stages. Hope that helps!
This reminds me of a true story from The early days of graphical interfaces. There was a computer that could be in two modes, EDIT or RUN. Unfortunately there was no indication of which mode you were in. If you were in RUN and you typed EDIT , you entered EDIT mode. But if you were already in EDIT mode, then typing EDIT was interpreted as Everything - Delete - Insert - T. The result was to wipe your entire programme and print the letter "T" in the top left hand corner of the screen.
npm
npm
Oh, but that's too funny!
Not necessarily to the person running it - but to me, yes!
Good thing that programming (and interfaces) have improved, yes?
Thanks for this anecdote.
