Ipad mini sound effects help
Jack1231
I have a iPad mini 32gb wifi only. But I've noticed that sometimes my sound effect will go very quite. The spud effects settings are full volume but sometimes it's very quite. Sometimes I've noticed a difference if I change the main volume or Siri's volume. But sometimes this doesn't work. Can anybody help please?
dhewson777 said:
Are these sound effects ones that you have added to the iPad?
No. The default ones. Sometimes the typing sounds, the lock sound, and the charging sound go really quite.
You will need to change your sound settings so that system sounds are not affected by you adjusting your volume with the buttons. Go to the General section in your Settings app and press the Sound line. Then, please see this:
You can make your system sounds as loud as you wish, then lock them so you can't change them with the buttons.
Hope this helps.
<img src="http://www.ipadforums.net/attachment.php?attachmentid=34054"/>
Hope this helps.
Yes I've already done that. But I think it might have resolved itself. It's been fine today
