iPad Pro 5th gen will not turn pages in Forscore Pro.
I could be wrong, but I'm pretty sure you need an iPad with Face ID to use this feature. The Face ID sensors can map your face in 3D, which makes facial expressions (and therefore gestures) easier to detect.
Up front, I have no idea how to help you with your problem. All I can suggest is going to the developer's website and checking out their knowledge base and user manuals; found rather inconspicuously at the bottom mo the page.
That said: Stuff you probably don't need.
Only the iPad Pro model support Face ID.
Face ID is not just a software feature. It requires extra hardware, which is not part of any of the basic iPad model.
Perhaps you don't have a 5th gen iPad. Actually, I'm pretty sure you don't. According to the support tables, the 5th Gen iPad can not run iPadOS 17. From what you've told me, it's more likely you have the 5th gen iPad Pro
The first link is to Apple's site listing which devices have Face ID.
The second link is to the Wikipedia page comparing all iPad models, OS's supported, and features. A great link to keep handy.
The last link is to Apple site, to help you identify which model you have.
Good luck solving your problem, or finding an alternative solution that will work. I saw something about using Airpods and using head motion to turn pages. Maybe that will work for you.
With respect, the OP does say in the heading they have an iPad Pro 5th Generation.
Actually, the local Apple store was the entity that upgraded my just-purchased, refurbished, 5th gen iPad to iPadOS17.1. I upgraded it to 17.2. I will keep working on this problem. I really want the gesture page turn feature.
Sorry I didn't catch that it is actually an iPad Pro. Good luck with your issue. There was another person asking about Forscore and gestures a few months ago. Maybe they'll read this and have a better answer.
