iPad Pro Installing at Glacial Speed
jchunter
Phoenix, Az.
Installing new iPad pro not complete after 24 hours. Some Apps have been copied from iPad3 but many more more have not and are labeled as "waiting" on the Pro screen. One, labeled as "loading" has been at it for 10 hours, with no end in sight. No indication of any data transfer taking place. How do I kick start this operation or determine its current state. BTW, Apps that have been transferred operate properly. The Pro is connected to power supply and wirelessly to wifi.
EDIT: Correction - The App Store displays only the word "loading".
Are you restoring your iPad Pro from an iCloud backup? Have you checked the strength of your internet connection? A weak connection can increase restore times dramatically.
Yes, restoring from iCloud. Internet was fine last night (~8). Today slower at 5 - 6 Mbps.
No. I hope that the fact that the App Store app seems to be busy, indicates that apps that have not been used in a long time might be getting pulled directly from the App Store list of owned Apps. Is this possible?
Restoring from an iCloud backup can last longer than a day, depending on your internet connection, and the size of the backup. Some time ago, when I set up a new device from an iCloud backup, the complete process took two or three days.
An iCloud backup does not contain the apps that are on your device. there's just the app data and a record of which apps they are and their location on the home screen. The apps themselves are downloaded from the app store as part of the restore.
What ever happened to the good old days of "blinding electronic speeds" ?? :):(
EDIT: Looking at my iPad3, the total cloud storage is 5 GB with 3 GB available, leaving 2 GB as the total volume. Even the venerable Apple 2 might have been able to move 2 GB in 24 hours... :):):)
Seriously, how much space is really being used for a backup? Are these cumulative over time?
For me, the app store has been slow to non-responsive more often than not for the last month or so. This is just for the usual app updates that appear every day or two, not restoring from a backup. Sometimes the "available" updates will be installed by the next morning, other times there are more waiting than when I went to bed the night before. Nothing has changed, and other Internet services are fine.
Apps in the process of being restored will occationally get stuck. Just restart the iPad and they should start downloading again. When the iPad is activly restoring apps you should see progress on one to three apps at a time.
Well, the installation is "stuck" aIlright. There has not been a scintilla of change in the last 12 hours in spite of resetting. This may well take weeks to finish. IMHO, the installation code is poorly designed, mute, with no progress meters or alerts that things are not going well. There could be a massive queueing bottleneck at the App Store. Not a good situation for Apple as it heads into the prime holiday sales season...
Do you have a recent iTunes backup you could try instead?
I checked my desktop computer iTunes and found a fairly complete list of the Apps on my iPad3. (I hadn't used iTunes for a looong time.) So, how to get iPad Pro authorized so I can sync them. (assuming this sync would be compatible with the install, which is evidently still running??)
Day four of new iPad Pro install: Last night I noticed that one of the successfully transferred Apps was an ad blocker ("WebBlock"). I opened it, found it was in the ON state, turn it OFF and noticed one of the folders seemed to be loading. AN hour later, I checked again and found four folders seemed to be loading. This morning they seemed to be still loading.
Frankly, Apple must be transferring data at less than a pitiful 10 bytes per second . Install process still completely mute and App Store still locked in a "loading" state.
