Ipad slow/freezing : 8.02 a Problem ?
borischelski
Doesnt seem to be a coincidence that since downloading my iPad constantly freezes and is very slow.Also I keep dropping off wifi.NEVER had any such probs beforehand.
For the record I have an iPad 2 wifi 32 gb.i have 4.5 gb capacity remaining.When experiencing these probs I always close all other apps but doesn't ssem to help
any advice greatly appreciated !
It shouldn't be a problem with your iPad 2. Mine is working fine on the latest software, which is 8.1.
In case you updated your iPad using Wi-Fi: use iTunes on your computer to restore or update it.
Update iTunes, backup your iPad and then follow these directions to restore: http://support.apple.com/kb/ht1414
To update, select your device, then choose "Check for Updates", and "Download and Install".
That done, reset it: press Home and Power button until the Apple logo appears, release both and let the iPad power up.
