iPad2 wifi and sound issues
Kish27
Hello,
I have iPad2 wifi model and it has couple of issues.
It stopped detecting the wifi routers even though my iPhone and iPad Air can detect and connect to the network.
I tried resetting option and even erased all data and made it like brand new device, still no use. It used to detect network but the signal strength was low even though other devices next to it have full signal. But after resetting the iPad it stopped detecting the network
Sound also became very low and I tried all options mentioned in the forum
Pls suggest a way out
Kish
Hello,
Kish
It's a good possibility that this is a hardware related issue. To find out for certain, it would be best to go to your nearest Apple Store and have them run a diagnostic on the device. They can tell you then if it is hardware related or software. If it's hardware related and your warranty is expired, then they can give you an estimate of the repair costs.
Sent from my iPad Air using Tapatalk
Probably not the issue, since you said it doesn't seem to detect the signal. But restarting the router will often help a device connect again. Router's can get finicky about what devices they let connect. Just because other devices are working is no guarantee that restarting the router won't solve the problem for another device.
Worth a try, anyway.
