Fjcunninghamjr
Using an iPad 4 gen, how can I tell if the battery has reached its end of life, since can’t get it to reboot or turn on?
thanks,
Frank
thanks,
Frank
There would usually be warning signs, ie needing to charge it more often. Can you get to an Apple Store, where they could run a diagnostics test?Using an iPad 4 gen, how can I tell if the battery has reached its end of life, since can’t get it to reboot or turn on?
thanks,
Frank
