More problems. Email vsnished, mail colapsed no memory, not in drafts help
Lisirein
I Erased app but about doesnt show that freed memory weird
Im writing a lot and stil many times the speling is ridiculus, no my, i know my is terible, no spell checker or dictionary no where, have only notes, but i type x and it writed y, weird why ?
What do to three problems
I'm not sure what you are asking. If English is not your primary language the forum has several boards dedicated to different languages. If you post there perhaps someone can help you in your native language. In the mean time I'll post some general fixes that often help with problems.
