Need help. For bouncing ball
twofeatherzs
I am new to the iPad. I am visually imparied. I had eye exercises on a p.c. But I do not have access to that pc any more. So does anyone know where I can get an app or program that has a ball that bounces on the screen. Also a ball in the center of the screen that changes size. It goes from very little to the size of the screen and then back to small. Back and forth like that. I would like any help, thanks.
There is an app in the App Store called "Eye exerciser" ($1.99, USD). It looks as if it may come close to what you need? There is a Lite version that you can try out for free to see if it does what you need or want. Then, if you like it, you can buy or upgrade to the paid version.
There are others, but maybe this is a good place to start? Good luck.
Hi and welcome to the Forum!
I hope others will be able to suggest more apps for you.
iPad 2 3G 64gb
