Need help with spreadsheets
Joan B.
New Mexico
Hi. My name is Joan and I am new here. I am really trying to figure out what the best spreadsheet is to buy for my small business. I need to keep inventory columns that I can create myself, and then format a P&L to give to my accountant. Also, can you email a spreadsheet to a regular laptop to print? There are so many different office apps you can buy that I could go broke before I found one that worked for me. Any advise out there? I have a lot to learn, but this is the stuff that is important and has to be put into action soon. Thanks.
Hi and welcome to the Forum!
I've moved your thread to our Help Section where you will receive a better response.
Hi Joan. I use ss's everyday. I use a program called Splashtop on my iPad and my work computer. It allows me to use excel (or anything else, since it is allowing me to use my pc remotely). I can email it, print with it, and anything else I could do if I were on my pc. I apologize if this is not what your looking for, but like you, I need to be able to use excel daily, and this works very well for me.
To be more clear, Splashtop is not a spreadsheet program, rather it is a program to allow me to use my pc remotely. There are others programs like it, this is just the one I use.
