Hi Meenie, check some buttons as they may have accidentally shifted. 1) Slide up from the bottom edge to reveal the sound slider in the control panel. Slide it to full on. 2) Move the sound rocker switch on the side of the iPad to full on sound. 3) Next to that sound switch is a little button. If you see a red dot there your iPad is set to Mute. Slide it off. 4) Close all your running apps still in cache by double pressing the On button and then sliding the apps up and off the screen. 5) And (whenever your iPad seems to "act up" a bit its always a good idea to reset it: Simultaneously hold down the On/Off and Home buttons until the screen blacks out. Keep holding both until the white Apple logo appears and then let both go. Then wait until your wallpaper appears. Restart your iPad. Hoping that helps
Andrew Sent from OZ using Tapatalk
