Philipdale
I have received a photo (jpeg) on an email. When I save image it shows only a square that shows jpeg in the middle. No picture --- what is wrong?
giradman said:Hello and welcome to the forum -
Typically an attached JPEG image will come into the iPad Mail app 'opened' in the message; then by pressing on the image a dialog box will appear allowing a number of options, such as saving to your photo app.
You might want to better explain what the attachment looks like on the email since the behavior does not appear to be the above. Also, how are you saving the image?
A further suggestion is to email yourself a message from another computer and attach a JPEG image, then see how it appears on the iPad - the problem may be w/ the image sent originally - good luck!
