Power point
drPr
I would like to create and show Power Points using iPad. Google Docs doesnt appear to allow ppt creation or editing with the iPad. Is keynote my only hope?
Drpr
I use Keynote for creating and editing existing PowerPoint presentations. You have to be aware (as I'm sure you are) that it's a stripped down version of the Mac iWork counterpart. But it's pretty good for basic presentations. If you import a presentation from PowerPoint that's very complex then it can struggle (a polite way of saying that it doesn't render the presentation correctly) but any presentation originated in Keynote will render perfectly in PowerPoint.
You're probably aware of the Apple Keynote help pages; they give something of the flavour of its capabilities but, just in case......
http://help.apple.com/iwork/1.3/mobile/interface/index.html#tan724868a9
I'll be sure to keep my eye on this thread as one of my main uses is MS Office apps. I am using QuickOffice and so far it is OK...not perfect, but gets the job done. I have been able to download Word, Excel, and Power Point docs from my email and open/save in QuickOffice. Maybe cause I am still new at this, but find some formats difficult to edit on Word.
The Power Point is a "read only" version, but if you are use to packing presentations, then that should not be an issue. I can see the thumbnails on the left of the screen and the presentation on the right and also close down the thumbnail view. Haven't played with the timing yet, but the graphics are wonderful and sure if I hooked up to an LED projector, the show would work well.
I went ahead and bought KeyNote and it is all right for what I need (so far). Thanks for the suggestions.
I hope it works out OK. If you have any 'issues' post them here and I'm sure they'll be someone who knows a solution or, at least, a workaround.
Is keynote also the only option to make notes on PowerPoint presentations. Im a student and I love using my iPad2 to red and make notes on PDF's and also just taking notes. But I'm still stuck with taking in my MacBook to follow powerpoints in class.
Any ideas or thoughts anyone?
Hi Tim:confused::confused:, (or anyone else) as you say Keynote renders perfectly in pp perhaps you can help me. I downloaded a keynote presentation (mine) from icloud as a pp file but while it appears on my pc as a pp file it will not open as a slideshow, so no transitions or effects. I found information that told me to export (via open key file, export to pp) but as pp does not work on ipad and keynote is incompatible with PC I am struggling to work out HOW!? i would be grateful for any advice as to how to do this. Thanks
