Problem with apps and io5
av8tor2413
I'm having a problem with new apps since I loaded io5.01 on my iPad. They seem to work fine for a day, but then when I select them, the icon blinks like it wants to open, then the app dies. Help!
I had this problem but as soon as I updated one of my apps on the iPad it all normalized. You could try that. It worked for another friend of mine too
If updating your iPad doesn't work, restore your iPad. It still saves your apps and music in their iTunes library, so if you don't have a library, make sure you sync your iPad before restoring it. This worked for my friend. Hope this helped! :)
Hi and welcome to the Forum!
Give these steps a try -
Do the four finger swipe up to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press one of these apps until they start to jiggle and red minus signs will appear above them all. Press all the minus signs, this will close them, not delete them. It's a good idea to do this regularly just to keep them all running smoothly, I do mine every night. Check and see if it is operating now. if not a restart is in order.
When your iPad begins to behave strangely these are the first steps you should do to rectify it. Let us know how you go, good luck!!
I did try all 3 steps with no avail. Any other ideas? Who and what source can I turn to to get help for Pages and Keynote apps? I appreciate your help
