Problem With Cydia Tweak Random Icon Flip
ssemmel:
I don't know the answer to your question. However, I moved it to be its own post in the main Hacking section for two reasons:
1) So more eyes can see your problem - and offer assistance
2) You had this question as an off-topic post in a thread about a theme. Thread hijacking is considered bad manners and is against the rules here at iPadForums.
All: If you have a question not related to the topic at hand, go ahead and start a new thread. That'll keep the boards nice and neat - and may help someone later on who might have the same problem find the solution.
Thanks.
I have it and no problems. Maybe it is interfering with something. Did the whole dock disappear, icons and all? Or just the background?
ssemmel:
Thanks.
Maryilyn,
I am truly sorry. I am new to posting in a forum and I didn't know if the issue was this theme or the tweak. Stacey
Ye, some apps can clash and themes etc and can make your iPad go crazy I installed themes and an app and every time I clicked on an app it would just bounce back to the spring board so I had to start from scratch. What was the last app you installed try uninstalling it and see what happens
Thanks I will try that. I did install infinidock and then unistalled it and still no icons.... very strange... the only other app I have is springtomize... maybe that is conflicting oh well....
