Problem with receiving emails
aoalf
I have problem receiving emails in my iPad recently. When I checked Settings and it gave the message "accounts are currently syncing". I did not do any new syncing prior to this problem except resetting the iPad as at that time I had problem playing youtube. I have tried restarting and resetting but the message is still the same. Because of this I am not able to receive any new emails. Has anyone encounter the same problem before and is there any solution? Thanks
Make sure you actually power off the iPad, not just put it in hibernate mode. When you power off correctly, you should get the slider button indicating to Power Off.
I have found that if something isn't working right, powering off and then powering back on solves 100% of the problems I had.
Beery
