Settings and Help
Roy Rob
The help sections says that settings can be tweaked by selecting the settings on your home page and scrolling down to the bottom to find this forum's app. It's not there? Any ideas folks?
Sent using my iPad 2 - 16Gb - Wi-Fi only
You have to go to the bottom right of this page and tap on more. That brings up this page.
image-2499689619.webp.
image-3919557910.webpIf you tap on settings and help you come to these pages. Tap on each menu item for more choices.
<img src="http://www.ipadforums.net/attachment.php?attachmentid=29927"/>.
<img src="http://www.ipadforums.net/attachment.php?attachmentid=29928"/>
<img src="http://www.ipadforums.net/attachment.php?attachmentid=29929"/>If you tap on settings and help you come to these pages. Tap on each menu item for more choices.
Thanks scifan57, I saw the 'more' part but that's not what I meant. I'm not sure how to post screenshots or I could show the help area I'm talking about. It definitely refers to the iPad Settings, scroll down to find the iPF app name and tap on that.....? This app is not there.....? Any ideas, should I reload the app?
Is this what you mean? This is in Settings>Notifications.
image-2970739805.webp.
image-1128779884.webpThis is what you see when you tap on the iPF icon.
To make a screenshot, press the home and power buttons and immediately release them. To post the screenshot, tap the advanced button at the top right of this page, select the attach from photos item in the menu. Select the correct item from the camera roll. When it finishes downloading, tap the item and a pop up appears, tap the insert inline button, then tap the send button at the top right of this page. Your post, screenshot included, will appear In the thread.
