Small box in corner
s00paSold3r
Houston,TX
today I just noticed a small box with a N in the top right hand corner near the battery meter when I am in email or on the web. I have done Google searches, and searched forums and cannot find out what this is or why its there?? Does anybody have any idea's??
You are most likely running backgrounder on a jailbroken ipad. The N appears when you have set a particular app to run in it's native multitasking state. The N means native. For example I have IM+ setv to run native so that I can continue to receive push notifications when I am not running the app. You can set which apps you want to run native by going into the backgrounder app.
It means you've been a very Naughty Boy!
And Mr Jobs is watching you ..........:)
Thanks Jake
:ipad-front:
:ipad-front:
Thanks Jake
:ipad-front:
:ipad-front:
Sure thing!
