Wifi issue at hotel - help!
ThePhotog
My wife had her 1st gen iPad - no issues. I had my 2nd gen and had trouble and wasn't able to get it connected until the very end of the meeting. And ideas?
ThePhotog
ThePhotog
What did you do at the end of your meeting to get it connected?
WiFi is always weird in ways. One time I connected to a public WiFi network, I fired up Safari and it said it connect to the Internet.
Tim,
That is exactly want I ended up doing was a reset. The signal strength on the wifi wasn't very strong.
Some hotel networks get overloaded during meetings, especially if there are seceral going on. Had that problem before.
