Sonny Burnett
Can anyone who has experienced WiFi issues with the WiFi only units test on the same router / firewall with a WiFi + 3G to see if the problem still exists?
I want same info as it is possible apple may have made changesSonny Burnett said:Can anyone who has experienced WiFi issues with the WiFi only units test on the same router / firewall with a WiFi + 3G to see if the problem still exists?
I now have both a 3G and wifi model in my home. I also have a dual band router, the signal strength on the wifi only model is noticeably worse than the 3G has been so far today. I haven't had any problems with the wifi only model dropping connections, but the signal strength is worse while sitting in the same spot connected to the same network as the 3G model.
OK, I am at my cigar store hangout on wifi right now, and have watched vid from ABCand used mail as well as posting this. I've seen absolutely no problem connecting or maintaining connection. I'm just amazed that the wifi speed is more than triple 3G.
What kind of cigars do you smoke?
Why does that amaze you?
A LAN based Internet connection will always blow away a cell based one.
Anything by Pete Johnson, esp. Tatuaje brown bands. Liga Privada from Drew Estates...waiting on the Dirty Rat release...Many others!
