wireless connection problem
shmily616
I lost connection to the internet in my home. Now when I tried to go on the internet on my i pad, it comes up with a box that says to put in the password. i put in the correct password, and it keeps saying It is not correct. has anyone had this problem? Thanks, Barb
So when you restored your Internet connection, what was the problem? Did you have to reset your router and maybe entered a different password? Did you enable your WiFi on your computer? You may want to go into settings, WiFi and click on your connection and tell it to forget this connection and re-connect to it. Be sure everything on your computer side of your connection is working.
Keep an eye on the shift key when entering the password. If you have auto-cap turned on you may be capitalizing the first letter of the password without knowing it.
This is not the iPad.either you are not entering the correct password or your wifi router is broken
Sent from my Blackberry...nah...just kidding
