Wireless keyboare problem
supreme689
I have a wireless keyboard for my iPad 2 when I type the number 8 I get 38 the numbers are doubleing up on me and with other keys also not all the keys
Sounds like a hardware problem with the keyboard; but in case it is not, try restarting and/or reseting the iPad to see if that helps. Turning the keyboard off then on (if you haven't done so) might also help.
