YouTube does not work
Ikrammama
Good evening,
I want help on my I pad 2 regarding YouTube. I want to know why is not my iPad working with YouTube. The last video was the video " assassin's creed literal" after that my YouTube app, when opened, shows a black background.
NOTE( my iPad is not a jail broken device and I don't intend jail breaking it)
Thank You
Maybe it was still on full screen? So it was left with a "blackscreen"... Or...
Try completely closing the app (including in the multi-taskbar) then restart your iPad.
Low bandwidth might be a possible culprit. Check your connection and strength. Some providers like schools will block things like YouTube.
Try this (from another thread w same problem)...
twerppoet said:
If you have not done so, try these common fixes.
Hold down the home button ant a bottom bar of aps should come up hold down on one of the apps and bolth the apps will wiggle and there will be a red minus in the corner of all of the recent apps in the bottom bar you must then press all of the red minuses until all of the recent apps are gone especially the youtube app after that click the home button again to close that bar and then reopen youtube and it should work if that soes not work then i would next try to restart my ipad.
