Zynga poker problem.
Trevayne
Hi, i've been having à problem with m'y zynga poker. While playing, thé image Will freeze and when it restarts thé hand i was playing is over, i list thé money i was betting and its now à new deal.... I actually list 1.5 millon$ (play money of course) but its à gréât frustration when it happens. Some people say its m'y internet connection but i havé à great connection and i always havé m'y 3 bars when playing.... When i write to zynga to complain they sayy they dont understand why this happens.... Your he'll would be greatly appreciated.
Hi there, not sure if you have done these immediate fixes...but gives this a try. Typically these steps will help when an app begins to act up.
Force the app to quit by pushing the home button twice to bring up your multi-task bar. This will show all the apps that you have visited. By long pressing the app in question, it will begin to jiggle-press the red circle with the negative sign on the app. It will only quit the app and not delete. Than try to re-open the app and test out.
Third is to do a soft reset by holding the power switch and home button together until you see the apple logo. Hope that helps! Let us know if that helped.
Also, moving this to the Game Section.
I think everyone with IPad has the same problem!! Me too, I get disconnected all the time. Think it's the wifi problem from IPad.
