30 Pin extension cable, longer than 5ft.
fuzzychicken
NYC
I wonder if anybody knows a place to buy 10ft 30pin exntension cable.Longer version of this product on amazon. All I find are about 4 ft max. I need 10 ft cable. I could use 3 of these but I would like to avoid that.
Thanks in advance.
(P.S. NOT USB to 30-pin cable)
Milton-Freewater, OR
Would an extension on the USB side work? Not only are they more common, they are cheaper.
Hold in mind that one of the reasons cables tend to be short is that signal loss over longer cables may cause problems. You could easily put those three together just to find it unusable.
