BCC problem
Dream
Twin Cities
Hello,
I am having a problem with all my emails being cc/bcc back to me. I went into the settings and turned that option off and it still does it. Any ideas?
longshanks
I too have this same annoying problem and it appears that there is no answer.
I have taken advice and turned off this function in ipad mail app but still it appears addressing every email I write to me as well as the selected recipient.
longshanks
Check your email account setting on the server (via the web). Sometimes they also have that setting.
Hi thanks for your reply, this problem is only on my ipad mail app, I use other devices ie, Linux laptop, windows laptop where this problem is not there.
BikeFlagAZ
Try using a web browser, rather than the built in mail app, to connect to your e-mail server. and see if you get the same result. Let us know what happens.
Milton-Freewater, OR
Since you’ve already turned off the Always BBC Myself option in Settings Mail, try toggling it. Turn it on for a while and send a few test emails, then turn it off again.
If that does not work you can try Reset All Settings in Settings > General > Reset. This does not delete content, apps, or third party settings. It will put most system and native app settings back to default, so be prepared to do some tweaking afterwords.
Be careful with the Reset settings. Don’t tap the wrong one by accident.
Note: Wow, they’ve really changed up Reset settings in iPadOS 15 Public Beta. Couple of new options, and different UI.
