linnormlord said:
Not sure if this is helpful here. The iPad definitely supports 802.11n, and all my other wifi devices do too. I guess if you're using the iPad on a network that has older devices, your suggestion is "don't"? Haven't heard that one before.
I'm using the ipad on a uk virgin superhub N router as me main DHCP and a netgear wpn824 b/g wireless router( access point )as second router for older device like a DS ,psp ,htc desire ,iphobe 3g,dell laptop ,asus netbook. Like i said on above post. It does and will affect certain wireless router if connected with b/ g and N device( crash).
Most 802.11n products will knock your throughput down by up to 80% if you use WEP or WPA/TKIP security. The reason is that the 802.11n spec states that the high throughput rates (link rates above 54 Mbps) can't be enabled if either of those outdated security methods are used.
The only exceptions are some products that are not Wi-Fi certified for 802.11n. The Wi-Fi Certification test suite checks for proper operation with WEP, WPA and WPA2. But if manufacturers don't submit their products for Certification, they may not lock out the higher rates. We also found early products using Ralink silicon also improperly enabled the higher rates when WEP and WPA/TKIP were used. But Ralink-based products that are Wi-Fi Certified now properly lock out the higher rages.
The bottom line is that you can only use WPA2/AES wireless security (or no security at all) if you don't want to throw away lots of speed.
